Fred
If you are getting fuel dripping from front and rear drain tubes, it has to be two seperate problems... Unless the whole fuselage is wet with fuel. Might want to take a look at the top of the gascolators. If they are not wet up there, be sure you have pushed the drain knobs all the way back in. If not that, it nearly has to be bad O-rings in both gascolators.
Jim Stack Richmond, VA |
| Thread Tools | |
