| Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
Rating:
Display Modes |
#24
I certainly see your point about wanting to have a custom panel built into the sim that exactly replicates one you own in real life, so the realism of trying approaches becomes that much more an aid. As a developer of these types of wares, I do have to say that it is quite difficult a challenge to create one or two panels of an example aircraft for use in Flight Simulator. Just one photograph if the panel is usually not enough to generate the correct look. I often take over 50 pictures of the instruments and panel when I do a walk-around of an aircraft. From these 50 or so pictures, a "composite" as you would say, is built taking pieces here and there and fitting them all back together to show a complete panel. It's a daunting task, and takes quite a bit of time. When we do create such aircraft panels, we try our best to accomodate most of the avionics that would normally be found in a said aircraft. As far as complex avionics go, there is a company that we are partnered with that provides highly advanced GPS units. I invite you to check it out: http://www.reality-xp.com Most of our aircraft come pre-configured so that if you own a Reality-XP unit, it will be selectable as an option in our configuration manager program. I understand that there are a lot of avionics packages out on the market today. Developing an exact working replica of each of those devices is incredibly complex, many taking years to get done (Reality XP has worked for over a year now on their upcoming GNS 430). A virtual Avionics shop is sort-of what R-XP is. But you see from their rather limited selection, that they take very long to develop. A good idea ... just not enough time or manpower to accomplish making them all. ![]() Regards, Owen
****** Owen Hewitt Greenwood, SC USA http://www.fsd-international.com |
| Thread Tools | |
| Display Modes | Rate This Thread |
