Old 12-03-04, 07:01 PM
mikecfc mikecfc is offline
mikecfc is an unknown quantity at this point
Riley Skyrocket for Sale
1976 Riley Sky Rocket N419
$170,000 or Best Offer
Here is your chance to own a 1976 Riley Rocket P337! Cruise at 260 Mph at Fl 20 in pressurized aircondiontioned comfort. This is a very desirable year model because of the large fuel tanks and the sliding rear seats. Plane is rigged for ice boots. It has a hot pilot winshield and a hot prop on the front.
Basic Stats:
3500 Total Time Since New
1100 SFREM Both Engines
1100 Since Complete Riley Conversion
1100 Front Prop
750 Rear Prop
Avionics:
KX155 Nav/Com (1)
KY196 Com (1)
KNS80 RNAV/DME
KT79 Transponder/Encoder
KR 87 ADF
KMA24 Audio Panel
WX1000 Stormscope
King HSI
KLN-90B GPS (IFR Cert.)
Dual Glide Slopes
Marker Beacons
S-TEC 65A Autopilot/Flight Director with Altitude Pre-Select
Equipment:
Long Range Fuel (148 gallons)
Riley Air Conditioning
Horton STOL
Hot Prop
Hot Windshield
Pressurized Mags
Super Soundproofing
Inflatable Door Seal
Digital Fuel Flow
Digital EGT and CHT
Radar
Fresh Annual
Complete Logs
Exterior: 8
White Base with Metallic Blue and Silver Trim (New Paint)
Interior: 7.5
Gray Leather
Perfomance Specs:
Maximum Speed
260 mph
Normal Cruise Speed
236 mph
Maximum Cruise Range
1590 miles
Rate of Climb
Twin Engine max at Sea Level
1,250 fpm
Single engine max at Sea Level
375 fpm
Certified Ceiling
20,000 ft
Takeoff Distance ( At gross weight)
945 ft.
Takeoff Distance over 50 ft obstacle 1,500 ft.
Landing Distance (At gross weight)
707 ft
Landing Distance over 50 ft obstacle 1,489 ft.
Gross Weight
4,700 lbs
Useful Load (standard airplane)
1,595 lbs
Fuel Capacity (usable)
123/148 gal
Baggage Capacity
365 lbs
Passenger Capacity
5
Engines (2)
Teledyne Continental TSIO-360-CB
Propeller
2-Bladed McCauley
Wingspan
38.2 ft
Stall Speed
55 mph
Centerline Thrust
No Critical V MC
Call if interested 310-717-6865
Ask for Michael Scott
