Unread 11-02-04, 08:30 AM
My question is, who is telling you you can't take your test in the 337?FAR 61.45b2 clearly states you can take the test in a aircraft that can't perform all the manuevers [VMC] but you rating is limited to that type of aircraft.[centerline thrust 337]. The inspectors hand book lists many examples of aircraft that require Centerline thrust limitations including many military jets[f4's, f18's, f111's]. Again is it a designated examiner or a actual FAA employee that is telling you this? Good luck
Ed Coffman
HEALTH STORE
