Old 09-05-04, 01:08 PM
Jose L. Ichaso Jose L. Ichaso is offline
Jose L. Ichaso is an unknown quantity at this point
Time between sparks plugs
Could any one remind me the time between changing sparkplugs, or your experience in durability for diferent brands.
Thank you
Old 09-05-04, 03:31 PM
I change them "on condition", that is, not at a set time but when their performance and appearance suggests a change. Typically, I inspect all plugs when the annual is done, since they come out for the compression check.
I would guess that they have been lasting about 500 hrs, but this is just a guess. It also depends on how you run your engine and probably whether it's a turbo or not. My experience is with normally aspirated and running at cruise 50-75 degrees rich of peak EGT, a setting which in my experience keeps the plugs nice and clean.
Saludos,
Old 09-05-04, 05:06 PM
I change our plugs @500 hrs. If they are kept properly gapped
and rotated at regular intervals they should make that with no problem.
Kim
Old 09-05-04, 07:40 PM
docbob docbob is offline
docbob is an unknown quantity at this point
An "erosion gauge", part number CT-482, is available from Champion for use with massive electrode spark plugs.
It will tell you when the plugs should be discarded. Most of us white-haired mechanics can tell by observation.
Old 09-05-04, 08:11 PM
Thank your all for your responses.
By the way Ernie, how did Frances in your airport and your airplane.
Saludos,
J.L Ichaso
Old 09-06-04, 12:22 PM
Jose, see response on another thread, with a graph showing hurricane tack: prediction vs actual.
