Unread 02-26-04, 08:30 AM
Prob have VAR Crank
I have been dealing with the VAR crank issue recently, so thought I would put my two cents in.
I would actually expect factory remans done in the 80's to have the VAR cranks.
I read the AD and some supplemental information on the TCM web site. It indicated that the factory started using the VAR cranks in overhauled engines in 1978. I also spoke with a rep. He said as far has he knew, all factory remans done since the early 80's had the VAR cranks.
