Unread 12-10-03, 07:18 PM
plastic dome light cover
need one for a 73p rick
Unread 12-12-03, 10:37 PM
come on "homers" somebody out there has an extra or knows about one. it is a two bit item that will go for alot more. would be really nice to finish my interior off.
Unread 12-13-03, 07:56 AM
Keven
Try Don Nieser
Rick:
Try Don Nieser, Preferred Airparts, or the other folks on Ernie's site. Somebody has to have it for a reasonable price . . . I think. Hey, I know, call Cessna.
Anyone else with any ideas?
Keven
Mexico Hotels
Unread 12-13-03, 01:41 PM
thank's i "e"'d don nesser. can't call cessna, no phone. all the replacement plastic parts on line do have. thank you rick
no response to my e-mail to don nesser, hopeully as an after thought someone will have an idea. thanks again
Unread 12-13-03, 02:56 PM
Rick, in Mexico, may have trouble doing a search. If someone can get me the part number (I don't have an illustrated parts catalog), I'll search for one.
Unread 12-16-03, 08:30 PM
ernie
i purchased the cd for parts and service from "mc curtiant", but it seems its generic and does not list the part number for the plastic dome lens for a 73p. so i have no way of getting a part #.
thank's for offering - rick
Unread 12-16-03, 08:43 PM
I'm seeing my A&P tomorrow and will ask him to bring the IPC so I can find the P/N.
Unread 12-17-03, 09:34 AM
OK, Rick, I got the Illustrated Parts Catalog (IPC) and found the dome light. The upper part of the figure below shows the dome light (extreme right, item number 16) for S/N's thru 1671, and the lower part of the figure shows it (item number 25) for subsequent S/Ns. Note that the latter one has a flat lens while the former one has like a diamond-shaped design at each end. I have the part numbers for both items. Let me know which one it is.
Unread 12-19-03, 05:08 PM
that was a lot of effort, thank you ernie!!!
i am not sure which one it is as my serial no# is 0002, but that is a riems number. if it would be possible can you look up both serial number types and i can go from there (one of them should fit a riems). rick
i owe you, a case of beer is waiting.
Unread 12-19-03, 05:51 PM
Rick:
I may have to look again at the IPC. The upper figure (for S/N's thru 1671) is also for S/N's F33700056 thru F33700076 and the lower figure is also for S/N's F33700077 and higher. I think that these are the French (Riems) S/N's. There probably is a different figure for lower S/N's, and I'll look for it next time I get the IPC.
Unread 12-29-03, 10:42 AM
Rick:
Looked yesterday at the Illustrated Parts Catalog (IPC) of my A&P but it's only for 1973 and after, and starts with S/N F33700056. If someone else has an IPC covering earlier models and can look up the part number, I'll try to find the part.
Unread 12-29-03, 11:51 AM
thank you ernie. don nesseer "e" me with two different part numbers. he does not have them, but this gives me a place to start. going north in feb for the annual and at that time i should be able to run the part down. thank's to all for your imput.
Unread 12-30-03, 08:33 AM
N456TL
I have Reims serial number number 19. How did yours end up in Mx as most stayed in Europe?
From the IPC for your serial number, FP3370001 thru FP3370008, figure 116, item 11, part number 1515021-1, LENS - DOME LIGHT.
If you like I can fax you the pages.
Have you tried the plane plastic folks as I think they had head liner and other stuff on their site, but come to think about it, I don't recall seeing the dome lens. I know that Libra Air Parts in California recently scrapped a 1973 P so they might be a source.
Regards - Dave
Unread 12-31-03, 02:22 PM
thank's to dave and all others i now have the correct part #.
it is much appreciated. rick
