Old 06-17-03, 08:16 AM
Bob Cook Bob Cook is offline
fuel flooding
Jerry
First test is to run with boost pump on low and see if this helps.
You need to go thru the fuel flow / pressure measurement / test per TCM.
My guess would be the barometric controller that governs the amount of fuel based on the upper deck air pressure. It is a closed loop and is probably the fuel pump or the controller.
Just out of curiosity did you try running on one mag while airborne to see if this could be a problem or at least eliminate a potential problem?
Do you have a jpi to see if there is one or two cylinders causing the problem in flight (roughness). Roughness is usually caused by an inbalance of fuel to cylinders or a mag(s) problem.
fyi
bob
