Unread 03-19-03, 09:36 AM
Bob Cook Bob Cook is offline
flap cable guide
Franciso
1) need to consult your parts manual for correct information regarding guides.
2) AC is telling you something.............
possible problems.
1) a roller guide or bellcrank has been overstressed and bracket is bent.
2) wing has been overstressed.
3) wing out of alignment.
4) Roller is exceptionally worn.
In summary there is something that is not right. Should inspect carefully to determine problem. Cables should not rub against any aluminum.
Is it aligned at other flap positions?
Is it one side or both?
Flap cables are vunerable to overstressing if airspeed exceeds design limitations........
a few suggestions
Bob
