Old 12-25-24, 07:54 PM
mdrob1985's Avatar
mdrob1985 mdrob1985 is offline
mdrob1985 is on a distinguished road
Same EIS question. I currently have 2- EDM 701’s and a Shadin. Need to come up three decades in tech and I want more accurate fuel sensors while I’m at it. The G-4 twin setup (packaged for a 337) is a fair bit lower priced than the alternatives and go into an existing panel cut out. I want it on the left panel for line of sight. I’m sure the 960’s are nicer but I don’t want another big square box cut out on my right panel. The G-4 can just go into one of the two remaining 3 1/8 holes on the left panel. I have to keep my T&B for the S-Tec unless I can get away with adding a GAD 43e. Not sure that would be a full replacement for the T&B for roll inputs? If so, all vacuum and analog gauges would be gone. How are you getting space in your center stack? For me, anything in the av center stack is not an optionas it’s too full already. A pair of GI 275’s would be great but cost is quite a bit higher than one G-4 which has a package already setup for the 337’s. I’d like to know what you decide to do. Please share a picture of your final setup. Mine is sitting in the shop pending a second fuel pump rebuild.
