Unread 10-13-24, 04:31 PM
If the gear "falls" uneven, it is air in the system which is difficult to get out.
(Just a pain to do., not hard)
How much extra 24 volt ext power?
The gear motor is a heavy draw, so turn off any and all electrics, not attached to the gear.
If the motor is old.. (which is probably, yeah.), the motor may be tired, and need a rebuild.
Do all of the locks "click" closed, and then the pump runs for another 20 seconds??
This system is troublefree- until it isn't.
Good luck.
>>>>>EDIT: I just read that the doors have been deleted from this aircraft.. I've never done one with the deletion mod. Take what I posted above with a grain of salt.<<<<<<<
