Unread 08-26-24, 01:54 PM
amexbmorgan amexbmorgan is offline
amexbmorgan is on a distinguished road
Thanks All
Joes - How do you do that? I have 337D, I thought it's a "printed" circuit board with a connection plug on the left lower side of the board.
I haven't got back there to see if it the temp gauges are connected differently.
Pretty straight forward on the oil pressure swap though. Discovered a low indicating oil pressure gauge by swapping the oil pressure lines.
Bryan
Unread 08-26-24, 10:21 PM
Joes Joes is offline
It's a Card Edge Connector Housing that slips over the circuit board flat. The card edge connector is a part number A-MP 582376-9 69-49 and uses pin number 530004-7 TERM EDGE DUOTYNE 22-26AWG CRIMP. I'm told that a Gottlieb Pinball Edge Connector Pin Removal tool will help swap the pins once they have been located.
I have a extra Cessna 337 Instrument Gauge Cluster PN# C669506-0202 Fuel Engine Cluster Gauge if you would like to swap it out without all the pin switching.
Joes
Unread 08-30-24, 01:36 PM
Ok- I know the oil pressure issue is not the gauge. Swapping the gauge confirmed same low readings.
I also was able to get the cold oil pressure adjusted to the top of green, however, it took almost all of the adjustment screw to get there. That is not right, I'm thinking to myself.
Is there anyone out there who is willing to have a call to talk things through with me about my issue.
I know I have an oil pressure issue. However, I can't determine, if it is the pump not producing or there is an internal leak somewhere downstream.
I think I understand how the governor sends oil to the prop (Full Feather governor), but want to clarify what I know before I start taking parts off the engine.
PM me if you have time for a call.
Bryan
Unread 08-30-24, 01:44 PM
Jhogan0101's Avatar
There is a spring, you can put washers in the shim/adjust the pressure. Best have someone thats done before with you. Not something you want to screw up….
337B
Philadelphia PA
Unread 08-30-24, 02:28 PM
kbecker kbecker is offline
I just went through this on my annual inspection yesterday. I was running 30 psi in cruise and wanted it around 40.
I purchased the replacement springs though Spruce, looking up the numbers in the IO360 IPC. The new springs were slightly shorter than the old ones, but made of larger guage coil.
My rear engine originally had the pressure adjustment just about all the way in, and changing the spring, which is stiffer, allowed us to adjust the pressure in the midrange.
The front engine adjustment was about 1/2 of the way in--changing the spring made the pressure too high, even at the lowest setting. So we replaced the front spring with the original one and turned it in somewhat to dial that pressure in.
Unread 08-30-24, 04:10 PM
Kbecker - Do you have a part number? I replaced my spring with one listed in the IPC, but didn't notice any difference other than color. New one was blue.
Bryan
PS. My new one was part number: 637083
Unread 09-01-24, 12:51 AM
I’ll look it up tomorrow when I have access to my laptop computer
