Unread 02-20-24, 07:16 PM
Well then, it appears you have your answer.
Why did you ask, if the answer you accepted, (and evidently called Textron and McFarlane) got their answer?
My first two questions still stand.
Have you seen this pump? Touched this pump?
Aircraft spruce page, weldon pumps.. listed at the top is PMA"d pumps,
17 boxes down is :
Cessna Single-Engine & 337 Aircraft 18000-B C291504-0201 Fuel Boost
08-07083
So, PMA'd, and listed for 337 aircraft.... Part number is correct, and if you call Weldon, I am pretty sure they will tell you it is the correct number.
OR
Don't take my word for it... Ask Weldon.
640 Golden Oak Parkway
Cleveland, Ohio 44146, USA
Info@WeldonPumps.com
PH: 440-232-2282
FX: 440-232-0606
Regards,
Randy
Unread 02-20-24, 07:22 PM
I just thought of one other thing....
YOUR maintenance manual, parts manual is up to date? Correct?
Latest and greatest version?
Perhaps a newer version has the correct part number listed, or lists a superceded part.
Regards,
Randy
Unread 02-20-24, 09:11 PM
YankeeClipper's Avatar
17 boxes down is :
08-07083
OR
PH: 440-232-2282
FX: 440-232-0606
Regards,
Randy
Well quite a lot transpired between 2:47p and your response.
I called Weldon during that time, for example, and they said that they had no PMA for pre-echo. In fact, the way they concluded that was by both of us browsing together to the FAA site where the PMA documents are published. We found eight of them, none of which mentioned anything before the echo models.
I have not seen or touched the pumps myself.
I saw the box you mean that only says 337, but if you click on the link for the part on that same line (for further details) it once again only lists Echo onward.
Good question about the parts manual... I'm still new to a lot of this; where can I find an updated version?
Unread 02-20-24, 10:27 PM
Frank Benvin's Avatar
I bought my pumps for my 1967 337b from https://aircraftaccessoriesofok.com/
Duke 4140-00-15 This was the physical part # on my pumps Luckily I had a couple spares from a 1967 337b parts plane
They had them in stock but you must return your cores There is a core charge which they return if your cores are good I had some extra pumps kicking around so I sent them in and they confirmed that they were good cores so i was never charged the core charge
I had to replace my pumps with an original the dukes the other pumps for the newer 337's are not certified for the older models
Pull the panel and see if you can see the part # on your pump
Hope this helps
Frank
1967 337B
Unread 02-20-24, 10:46 PM
Oh I know those guys...got a governor or two from them. Didn't think to call them for an overhaul of the pump though.
Thanks for the suggestion.
Unread 03-04-25, 06:49 PM
SteveG's Avatar
SteveG SteveG is offline
After a cold flight yesterday my C337A has come down with a runny nose (boost pump overflow drip). I can't add much to the previous posts on this topic but... Repair or replace options now seem to be: Dukes overhaul at $1350 + $600 core, McFarlane (CJ Aviation) at $975 + $50 core or Weldon at $925 + $100 core. As previously discussed the McFarlane & Weldon pumps do not have the A thru D models included on their applicability lists. I'm just wondering if anyone has actually installed one of the non-Dukes options with the blessing of an IA or if everyone has eventually opted for the Dukes overhaul. It just seems crazy to pay $425 additional for an "overhaul" that no doubt reuses the same motor, housing, head casting, etc. such that all one is actually receiving is a reseal than to buy all new just to satisfy some obscure paperwork when all of the part numbers are interchangeable. I'm leaning towards the Weldon pump but if anyone has any experience with that solution I'd be grateful for your hard earned experience report. Or any further thoughts on the matter from others.
Thanks, Steve G.
Unread 03-04-25, 06:56 PM
Thanks, Steve G.
See my post above You need to replace with the dukes with dukes The other ones are certified for the newer model 337's not our older 337's The fuel pumps in the older models are in the wings the newer ones are located in a different place the engine compartment if i remember correctly My mechanic told me to replace with the certified ones for my 337b I am located in Canada
1967 337B
Unread 03-04-25, 07:42 PM
I'll ask my IA tomorrow how we resolved. I don't recall breakfast, so...
