He didn't drop the ball--he said new is difficult to find but he could send out for overhaul with about a 2 week turn around. Then I started to look around for new. I think I still agree with him.
I saw what you refer to there, but when you go to the eligibility list, it does not include models before Echo. Even though Spruce and others say that 18000-(x) replaces 291504, it only means it replaces it where the 18000 has a PMA. I went on the FAA site and saw that it too only mentions Echo onward. I wondered if it "really mattered" since hey--same old part--why not same replacement part? Nope. If it ain't PMA'd for your aircraft it ain't legal. And while we all know it "won't matter" in any practical sense, again, it could become a liability some day if the FAA ever found their noses in my (likely wreck of an) aircraft. I called both Textron and McFarlane (who also carries the Weldon 18000) to ask if I can just use the 18000, and both said not legally. |
Well then, it appears you have your answer.
Why did you ask, if the answer you accepted, (and evidently called Textron and McFarlane) got their answer? My first two questions still stand. Have you seen this pump? Touched this pump? Aircraft spruce page, weldon pumps.. listed at the top is PMA"d pumps, 17 boxes down is : Cessna Single-Engine & 337 Aircraft 18000-B C291504-0201 Fuel Boost 08-07083 So, PMA'd, and listed for 337 aircraft.... Part number is correct, and if you call Weldon, I am pretty sure they will tell you it is the correct number. OR Don't take my word for it... Ask Weldon. 640 Golden Oak Parkway Cleveland, Ohio 44146, USA Info@WeldonPumps.com PH: 440-232-2282 FX: 440-232-0606 Regards, Randy |
I just thought of one other thing....
YOUR maintenance manual, parts manual is up to date? Correct? Latest and greatest version? Perhaps a newer version has the correct part number listed, or lists a superceded part. Regards, Randy |
I called Weldon during that time, for example, and they said that they had no PMA for pre-echo. In fact, the way they concluded that was by both of us browsing together to the FAA site where the PMA documents are published. We found eight of them, none of which mentioned anything before the echo models. I have not seen or touched the pumps myself. I saw the box you mean that only says 337, but if you click on the link for the part on that same line (for further details) it once again only lists Echo onward. Good question about the parts manual... I'm still new to a lot of this; where can I find an updated version? |
I bought my pumps for my 1967 337b from https://aircraftaccessoriesofok.com/
Duke 4140-00-15 This was the physical part # on my pumps Luckily I had a couple spares from a 1967 337b parts plane They had them in stock but you must return your cores There is a core charge which they return if your cores are good I had some extra pumps kicking around so I sent them in and they confirmed that they were good cores so i was never charged the core charge I had to replace my pumps with an original the dukes the other pumps for the newer 337's are not certified for the older models Pull the panel and see if you can see the part # on your pump Hope this helps Frank
1967 337B Flying in Skymasters since I was 16 Last edited by Frank Benvin : 02-20-24 at 10:43 PM. |
Oh I know those guys...got a governor or two from them. Didn't think to call them for an overhaul of the pump though.
Thanks for the suggestion. |
After a cold flight yesterday my C337A has come down with a runny nose (boost pump overflow drip). I can't add much to the previous posts on this topic but... Repair or replace options now seem to be: Dukes overhaul at $1350 + $600 core, McFarlane (CJ Aviation) at $975 + $50 core or Weldon at $925 + $100 core. As previously discussed the McFarlane & Weldon pumps do not have the A thru D models included on their applicability lists. I'm just wondering if anyone has actually installed one of the non-Dukes options with the blessing of an IA or if everyone has eventually opted for the Dukes overhaul. It just seems crazy to pay $425 additional for an "overhaul" that no doubt reuses the same motor, housing, head casting, etc. such that all one is actually receiving is a reseal than to buy all new just to satisfy some obscure paperwork when all of the part numbers are interchangeable. I'm leaning towards the Weldon pump but if anyone has any experience with that solution I'd be grateful for your hard earned experience report. Or any further thoughts on the matter from others.
Thanks, Steve G. |
1967 337B Flying in Skymasters since I was 16 Last edited by Frank Benvin : 03-04-25 at 06:59 PM. |
| Thread Tools | |
