Old 01-25-24, 04:46 PM
CenterlineT CenterlineT is offline
CenterlineT is on a distinguished road
It seems the static system senses more ambient pressure outside vs inside the cabin.
I don't know if you have two static ports or one. If you have one port then the heavy wing maybe the culprit (the static port faces the wind which it will compensate if there are two ports one on each side of the boom or fuselage, but not with one port) . For that you may want to check the rigging and also do a weight and balance to make sure your heavy wing is either weight related vs control surface vs wing or tail boom misalignment related. That may solve both your problems.
