Unread 10-07-23, 03:33 PM
I was thinking of just filling the strut with air until I could get it to another shop for annual, then have them perform the service with nitrogen. The problem I have is to fill the strut with air, the valve is on the backside of the nose strut and when the strut is down it's in an alcove (I have a 1966 337A). I can reach around in the cramped space, but I can maneuver to remove the cap (which I think I can feel there) or get an inlet nozzle on it. From what I read in the forum, I have to be able to release the nose gear lock and shift the nose gear forward to get to it. There are 3 ways to do this from reading the forum:
1. Lift the entire aircraft up as you are performing gear retractions which requires a lot of jacks.
2. Lift front nose with jacks or pushing the tail down, pull the landing gear circuit braker, set the gear to up position, turn the master switch ON, then for a moment push in the circuit breaker, then pull. (I worry about the main gear and if I'm setting up a gear collapse situation either during the procedure or while taxing. I also don't have a circuit breaker I can pull manually).
3. Someone mention taking the rear door on the back of the nose gear which I don't think I can do that as just an owner, that sounds like A&P territory.
I plan to go down tomorrow with an endoscope I bought to attach to my phone to confirm I am indeed feeling the service value, but I can try to reach it again, but I don't think there is enough room to work with the value.
If anyone else has a non-gear retract or a way to safely release the nose gear uplock that doesn't sound like it would give me a gear collapse situation, I would appreciate it.
Karl
Unread 10-07-23, 11:13 PM
Frank Benvin's Avatar
My mechanic filled it while I pulled down the tail and rested the tail on a upside 5 gallon bucket with a pillow on top of it. The nose gear was down and locked while he filled it
1967 337B
Unread 10-08-23, 01:15 AM
I am headed to the hanger tomorrow. I will check again. Maybe I can get to it if the strut is extended or maybe I was looking in the wrong place. Let you know if it works.
Karl
Unread 10-08-23, 08:18 PM
I used a single short jack on the jack point behind the nose gear. I have weighted the tail end down with cases of oil in a pinch (@8- 12 qt.) The nose wheel needs to be off the ground to service it. If you try to do it with weight on it, it will take 250+ psi to get it to move.
Unread 10-08-23, 10:32 PM
I went down today to see if I could get access to the Schrader valve to put in some air. It looks like there is a metal cap that can be loosened with a hex wrench, but try as I might, with the aircraft not jacked up and the strut deflated, I could not maneuver my arm in there without hitting the side of my body or head on the gear doors. I'm going to have to purchase a nose jack and try again later. Good news is it looks like my A&P is finally starting to move through his backlog of aircraft for annual. Wither he fixes before I get to it or not, I need to learn how to do it, so I will keep trying to work with it.
Thanks everyone for your help,
Karl
Unread 10-09-23, 01:26 PM
The cap on the valve should be able to be loosened with your fingers
You can see it in the picture attached
Frank
1967 337B
Unread 10-10-23, 10:11 AM
Thanks Frank.
That's what mine looks like, good to see I'm on the right track. I was also looking at a nose jack as my first jack purchase. I was looking at Alpha Aviation (those are the red hydraulic jacks I see on Aircraft Spruce), but I can't find the specific model for the nose. Does anyone have a recommendation for a nose jack model or even another company?
Karl
