| Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
Then it probably is mains actuator. Give us tips and tricks for pulling that. I have had it in my mind to prophylactically pull and overhaul mine.
But two other things (I'm sure you looked at): Brake system also uses hydraulic fluid and has flexible lines at pilot left foot and near rear passengers hip that won't last forever, could crack and leak. These areas could flow into belly. You are D model, so "power pack" (more properly control pack since engine driven pump powers things) has a hydraulic fluid catch tray under it and drain tube runs loosely into belly. Be sure "power pack" not leaking. |
We rebuild the acuators and replaced all hoses . After flying it for a while I topped up reservoir and went flying Parked the plane and found a small bit of fluid dripping from the belly Looked for the leak everywhere and could not find anything We even put the plane up on jacks and cycled the gear to look for the leak. We figure that the reservoir was overfilled and leaked out the overflow while in the air getting sucked into the belly It has stopped leaking since.
1967 337B Flying in Skymasters since I was 16 Last edited by Frank Benvin : 09-05-23 at 04:24 PM. |
| Thread Tools | |
| Display Modes | Rate This Thread |
