Unread 08-24-23, 09:28 AM
Gord Tessier's Avatar
Exclamation C-FTES gear up landing
All, on Aug 13, we had a gear up landing. The gear would not deploy, tried everything including adding oil to the gear pump that we had on onboard. All hydraulic fuid pumped itself overboard. Manual pump also pumped all the fluid overboard. Culprit was a failed nose gear actuator as per the attached photo.
Perhaps check yours for leaks etc. It's easy to overhail them and a lot less expensive then a gear up landing.
Gord
C-FTES
Unread 08-24-23, 04:17 PM
Frank Benvin's Avatar
Sorry to hear that - bummer Three yrs ago we rebuilt all actuators and replaced all the hoses for the gear - brakes and fuel systems. Some of the fuel hoses were hard and brittle Easy to break if you flexed them Guessing the heat from the engine takes a toll on them Another thing to check. Wouldn't want a fuel line to let go in flight.
1967 337B
Unread 08-24-23, 04:28 PM
Thanks Frank, I just wanted to get it out there. May save someone else some grief.
Gord
C-FTES
Unread 08-28-23, 05:42 PM
rmorris rmorris is offline
Who did you use for rebuilding all the actuators? Works be interested in doing it, just as a prevention thing.
Unread 08-28-23, 06:01 PM
They are actaully pretty easy to rebuild apparently. My AME (IN Canada AME = A&P) said he could do them.
Gord
C-FTES
Unread 08-28-23, 06:11 PM
My AME in Canada rebuilt them ordered the guts that he needed and rebuilt him. Wasn't a hard job as long as the rods and cylinders are in good shape
Frank
1967 337B
Unread 08-28-23, 10:06 PM
I’ve resealed many over the years and it’s not hard to do. Looking at Gord’s picture it looks like the snap ring on the end cap failed and the end blew out
Unread 08-29-23, 06:45 AM
It
That’s exactly what we think happened. We put it back together and the gear worked fine in manual mode. Pump burned itself out though.
Gord
C-FTES
