Unread 01-11-03, 05:38 PM
Re: temps
Originally posted by Bob Cook Some people will use the PEAK on the JPI/Gem to determine peak but there are *5* more cylinders to LEAN before you are LOP.
Bob,
Agreed. LeanFind mode tells you the first to peak - and for LOP operation you need to know which peaks last (i.e. the richest cylinder).
Here's two thoughts about how to deal with this:
1) Use the LeanFind mode "in reverse." If you use LeanFind beginning from LOP and richen the mixture, the first cylinder to peak will be the richest - so you can use that as the reference, and lean out the misture until you've hit your desired delta LOP temp.
2) Or, JPI offers a $100 update to the EDM-760 to give it the “Overlean” feature, which is an icicle display that helps you setup LOP.
