Old 07-10-23, 10:24 PM
Joes Joes is offline
Was this issue ever resolved????? I currently have something similar going on. Any help would be appreciated.
Old 07-11-23, 11:23 AM
B2C2 B2C2 is offline
None of these replies mentions examining the air induction path to the engine. If there is blockage there the air delivery will be at reduced pressure to the turbo. If this is large enough it will prevent the turbo from developing full inlet pressure. A clogged inlet path or airfilter could cause this. During the bad fire seasons we had on the west coast the air filter on my turbo was clogged significantly with smoke particles. I did not see a turbo pressure issue but didn't take it to high altitude much either.
As a side note I had a problem where I could not get to full inlet pressure on my front engine a few years ago. It turned out the magnet that holds the emergency air inlet closed had fallen off and damaged the impeller on the compressor side. For the posts where the turbo was replaced this obviously isn't the issue but if its a new observation make sure to get a look at the impeller to make sure its not damaged.
Old 07-12-23, 06:49 AM
Found the leak! After pressurizing the compresor and the exhaust system I found a massive leak at the collector/ball assembly. Also just a few minor leaks on the injector o-rings. Thanks for all the input from the past and present. Joe
Old 07-12-23, 09:52 AM
Would you mind posting a photo of the exact location of the leak? As close-up as possible? TY!
Old 07-12-23, 10:46 AM
Here ya go
File Type: jpg Screenshot_20230712_104232_Photos~2.jpg (205.1 KB, 5564 views)
Old 07-12-23, 11:10 AM
Thumbs up
Originally Posted by Joes View Post
Here ya go
Great pictures!!!
Old 07-12-23, 06:22 PM
On the compressor side just remove the air filter and construct a plug made of high density foam with hole for a shop vac hose. The same for the exhaust side thru the exhaust pipe. Best to use a high pressure vacuum reversed. Joe
Old 07-12-23, 11:05 AM
Dr.Dan's Avatar
Dr.Dan Dr.Dan is offline
How did you pressurize the system?
Cheers,
DD
1973 T337G
