Unread 07-09-23, 11:08 PM
amexbmorgan amexbmorgan is offline
amexbmorgan is on a distinguished road
Yeah - I had both pumps and dividers rebuilt. Front is fine, rear hight pressure is low.
I guess is need to fiddle around a bit.
Unread 07-10-23, 07:50 AM
Joes Joes is offline
Thanks for the helpful information on this issue. I found this article, hope it helps. Had been fighting this issue for a while.
Now find your engine model number on TCM SID97‑3 and verify your unmetered fuel pressures are within limits at idle and at full manifold pres*sure. Let's talk about the term "within limits". I have found that on the TSIO‑360‑GB and ‑LB engines, it is best to set the idle pressure right in the middle of the limits, but the full power pressure should be set at the maximum pressure setting. The reason? When the engine gets hot, the metered fuel flows tend to drop causing a lean engine just when you need a richer (cooler) engine. Even if you have a new engine or a recent fuel pump overhaul, don't think you are okay. Never have I seen a TCM or any other overhauled fuel pump set up for maximum pressure at maximum mani*fold pressure.
Unread 07-10-23, 01:19 PM
I found this article.
Looks like I might be building testing gauge setup.
https://www.tennesseeaircraft.net/20...id97-3e-again/
Bryan
Unread 07-11-23, 11:29 AM
B2C2 B2C2 is offline
I take my 1969 T337D to TriValley Aviation at KLVK. They are pretty competent and can probably do this for you.
Unread 07-11-23, 01:38 PM
Perfect. I'll reach out to them.
Unread 08-02-23, 04:54 PM
TriValley Aviation at KLVK got my fuel flow issue resolved. They were awesome!
Unread 08-03-23, 06:43 PM
TSIO 360 Metered Fuel Pressure Settings simplified
Thanks to Dan M. for the breakdown into the metered pressure analysis and for taking a look at an alternative approach to setting these pressures. Joes
ps: the articles pages are not in order.
File Type: png Screen Shot 2023-08-03 at 6.36.29 PM.png (261.6 KB, 2896 views)
File Type: png Screen Shot 2023-08-03 at 6.36.58 PM.png (180.1 KB, 2536 views)
File Type: png Screen Shot 2023-08-03 at 6.36.09 PM.png (166.0 KB, 2620 views)
File Type: png Screen Shot 2023-08-03 at 6.37.14 PM.png (51.0 KB, 2593 views)
