Unread 05-06-23, 07:21 PM
general's Avatar
general general is offline
Definitely more to the story an engine out should not be an issue at all
General Sky
Unread 05-10-23, 10:28 AM
Burt Burt is offline
Skymaster Down (Billings, MY)
Here is a link to a picture of the crash in the Billings newspaper:
https://twitter.com/billingsgazette/...09653174743052
Unread 05-10-23, 03:14 PM
Frank Benvin's Avatar
Good to hear the pilot survived. Hopefully we will hear from him on exactly what happened .
1967 337B
Unread 05-16-23, 01:32 PM
NTSB issue the preliminary report into an accident involving a Cessna P337H Pressurized Skymaster, N62PC, that occurred on May 3, 2023, near Laurel Municipal Airport (6S8), Laurel, Montana:
On May 3, 2023, about 0815 mountain daylight time, a Cessna P337H, N62PC, was substantially damaged during a forced landing near Laurel, Montana. The pilot was not injured. The airplane was operated as a Title 14 Code of Federal Regulations Part 91 personal cross-country flight.
According to the pilot, this was his first flight in the airplane since he purchased it last year. He had planned a cross-country flight from Bozeman Yellowstone International Airport (BZN), Bozeman, Montana, to Beatrice Municipal Airport (BIE), Beatrice, Nebraska. The takeoff and climb to 11,500 ft was normal. He descended to 9,500 ft to avoid clouds. During the ascent back to 11,500 ft, the pilot reported that there was an oil pressure drop and a spike in oil temperature for the rear engine. He was near Laurel Municipal Airport (6S8), Laurel, Montana, and decided to make a precautionary landing.
The pilot stated that he set up for landing, shut down the rear engine, and secured the propeller. He was about ¼ mile from runway 22 when the airplane lost altitude and airspeed. The airplane stalled about 10 ft above ground level (agl) and impacted a drainage ditch.
The airplane was recovered for further examination.
1967 337B
Unread 05-21-23, 02:32 PM
bigcheese
Based on my own one time issue....
If not prepared for glide ration with prop feathered, it can be startling.
It is easy to forget the 337 has something like a 12:1 glide ratio.
If you feather the rear prop, (instead of just throttle back),
the 337 becomes a sail plane.
My one rear out even decades ago was rather ....amusing, and educational.
The rear engine started burping just a few miles from Potomac Airfield (home),
on a busy Saturday afternoon.
I shut it down, feathered prop, and to make room, then declared over unicom,
"Potomac traffic, 86121, straight in 24, 2 mile final, engine out'"
I throttled the front back, setup to land, and it just kept flying, and flying and flying.....
A hushed silence as everyone awaited the fireball.
The friend in the airplane with me noted, "This airplane just isn't descending !!!"
I realized I was going to overshoot our 2,600 ft runway
deep in a ravine and valley
surrounded by tall trees.
So around 300 ft up, I gave the front full power and said, "N86121, going around."
Which I did.
Realizing I was just a heavy C182, I planned better, came around again and landed.
It was loose screws on the rear mag out of maintenance.
Try THAT in another airplane!
And THAT is why I like the 337 Skymaster!
Unread 05-23-23, 02:26 PM
Great story! And another reason to find a 337 with the rear engine access hatch in the rear firewall - makes mag access SOOOO much easier!
