A smart, thoughtful pilot like yourself would benefit greatly from a recording engine monitor. Once you have one, you'll wonder how you ever flew without it.
Engine Analyzer Options
The current best options seem to be:
JPI 790 Would fit nicely bottom of my avionics stack. Maybe I unconsciously had it layed out that way... Upside - 'Simple,' lowest installed cost ( I think) Downside - A ton of wires from engines, but sufficient to do the trick. The other option Suite of EI CGR units to replace EVERYTHING Two CGR 30P, one for each engine, replace MP and RPM and a CGR30C where Shadin is, to replace everything else The appeal to EI is a hub in each engine and minimal wiring from there to gauges. Going through an extensive annual 'wallet-ectomy' this year, and replacing the last window (front) because it's not as nice as all the other ones which are new 'solar grade'
David Wartofsky Potomac Airfield 10300 Glen Way Fort Washington, MD 20744 |
Other than grossly exacerbating the "wallet-ectomy", is there another reason a pair of Garmin GI-275 EIS gauges didn't make your best options list to replace everything? They're at the top of my list, but now I'm worried I'm not smart or thoughtful enough. |
Gi 275
Good catch! I handn't thought of those.
Looks like $8k for the two displays, plus install. One for each engine. Even handles 4 tanks. Hmmm. Interesting..... I see an STC to install, but do they officially replace need for existing fuel gauges?
I think a pair of GI-275 EIS's would replace everything engine-related, including the fuel levels on at least four tanks, and be STC'd as primary-- even on our Skymasters according to the AML.
My family has 275s installed on one 337E and I'm doing another install now on my 337G.
They are excellent instruments but assume 10-13k all in after sensors and wiring. If you have capacitive fuel senders you'll need to change them to CIES as the cap versions aren't supported by the 275. Cheers. J |
Good point on the CiES senders-- we did that during the last annual and it added ~13k combined for parts, markup & labor. Granted, a very significant chunk of that was removing and re-installing the Flint tip tanks as that's the only way to access the senders in those. YMMV. The CiES also require a dedicated ground wire, as I recall-- no big deal but maybe a bit more pricey since it is pressurized.
| Thread Tools | |
