Unread 03-14-22, 05:37 AM
SkyMac's Avatar
SkyMac SkyMac is offline
Hi Chaps
Apologies for the basic question, are the tubes marked with an up so that it can assist with installation or is it as simple as wires to the top.
Regards
Dave S
1974G
VH-DCS
Unread 03-14-22, 07:40 AM
Joes Joes is offline
Capacitance Tube Orientation
The orientation of the tubes were with the white plastic insulator on the bottom.
Unread 04-05-22, 06:30 PM
hayesjaj hayesjaj is offline
I'm going to pull mine in the next week for a CIES update, I'll take pics if you still need them. They are very easy to remove and generally easy to put back in.
Unread 04-05-22, 08:05 PM
Let me know how that CiES install goes. Mine was a bear and I have a blank spot between 35-50 gal per wing. Talked to CiES at AEA last week and think I can reorient my inboard sender to eliminate the irritating lack of fidelity between 35-50 gals.
‘77 NA G model with long range tanks (150 gal).
Unread 04-05-22, 08:25 PM
Will do! I’m doing my 73G and my brother is doing the family 69D so we will have a few good datapoints.
Unread 04-05-22, 10:55 PM
What is the orientation recommendation from cies?
Can sensors be installed without removing upper wing panels?
This is a near future project for me.
Unread 04-05-22, 10:59 PM
For my 337G i’ll have to pull the wing panels since the access doors aren’t large enough to pass through the large flange. On pre 73 models (verified for 69) the resistive senders are smaller and can be pulled without removing the panels.
As for orientation, tbd.
