Old 02-10-22, 01:23 AM
Use search function on this website and enter primer. There are a number of threads about this.
Old 02-10-22, 11:24 AM
SierraYankee's Avatar
SierraYankee SierraYankee is offline
SierraYankee is on a distinguished road
THANKS. Found the discussion. Thinking about removing them.
Old 02-11-22, 05:26 PM
My 1978 P337H POH mentions the primers as being useful in extreme cold weather starting conditions, but IIRC no exact temps are provided.
Primers could also get one of your engines started (in a pinch) in case your electric boost pump failed.
Yes, there are other much longer threads, but this is about the gist of it.
Old 02-12-22, 02:03 PM
THANKS I will check
Old 02-12-22, 06:13 PM
My 1978 P337H POH mentions the primers as being useful in extreme cold weather starting conditions, but IIRC no exact temps are provided.*
* The same cold-weather ops POH section recommends draining the oil when leaving the the plane overnight in an extreme-cold location. Suggests storing oil in a warm location, then re-filling engine with the warm oil before start-up.
