Old 10-19-21, 09:01 PM
Jhogan0101's Avatar
I have one of these lights, pretty bright. Maybe you could route it through the cowl flap and mount in a few different positions. Bit of a pain in the ass but i think you’ll see the problem.
Dual Lens Borescope-Endoscope, Teslong MS450 Inspection Camera with 4.5 inches HD Screen, 16.4ft IP67 Waterproof with 7 LEDs, Scope Camera Flexible Cable, Zoom, 2500mAh, 32GB Card for Drain Plumbing https://www.amazon.com/dp/B0819Q2YLK...ing=UTF8&psc=1
337B
Philadelphia PA
Old 10-19-21, 11:06 PM
Look at the black carbon on the back of the spark plug!!!! Leaking fuel has been burning off there for hours, probably leaking from the injector near it!!! Only by the grace of GOD have you not had an engine fire.
Old 10-19-21, 11:23 PM
Agree
I think I also see some slight carbon on the injector nut (side facing spark plug) and on fins below injector. Highly suspect a leak at injector line-nut-injector. Those welded joints where the compression fitting is like to crack. At least that’s what I’ve run into.
