Unread 12-19-06, 06:26 PM
That's some good info about the fuel strainer. I will certainly put that in my shop notes. However my actual fuel valve is what's acting up. So I might have to pull it out and rebuild it; however, there is no easy way to do that because of the tight space in the wing.
Does anyone know of a short cut to remove the fuel valve from the wing?
Unread 01-31-11, 11:23 AM
Tony
Skymaster337B, Did you ever sort out your fuel selector problem?
Unread 01-31-11, 04:11 PM
No, do you have a 411 on a gasket part number?
Unread 01-31-11, 05:58 PM
Item 10, is this the gasket (packing) you are looking for?
M83248/2-906
Name:	Snapshot 2011-01-31 17-51-58.jpg
ID:	2418   Click image for larger version
Name:	Snapshot 2011-01-31 17-52-41.jpg
Unread 02-01-11, 05:33 PM
Thanks for asking. But item #10 is an o-ring, around a b-nut. The gasket I'm talking about is a cork type gasket that seals the entire wing-mounted fuel selector valve body. Unfortunately the parts manual only lists it as a complete assembly. I new assembly was $15K the last time I checked...not going to happen. I will make my own gasket if I have to, but always like getting new parts if they are available...plus the maintenance down time is quicker.
Unread 02-01-11, 08:55 PM
Check McFarlen Aviation, they just started selling kit for cessna valves. Just put one in our 185 and it was @$90.00 Don't know if they have kits for 337's though. you can check their web sight
Kim
Unread 01-04-12, 09:20 AM
awilps's Avatar
awilps awilps is offline
awilps is on a distinguished road
Hi all! I'm new to this forum, and just wanted to share that we located the cork gaskets for our O-2's fuel selector valve at B & S Aviation in Wichita. $75 a piece. They should arrive today! Hopefully a better solution than the $12,000 Cessna wants for a new valve. I'm a bit unnerved by the numerous listings of parts for this valve listed as "non-procurable" and "discontinued". Coupled with several overhaul shops telling me they won't touch these units...is there a serious problem with opening these units up? I'm new to the airframe and want to give our MX team as much info as I can. Cheers!
