Unread 09-06-20, 09:39 PM
Jhogan0101's Avatar
Maybe check and see if both dipsticks are the same. Cant imagine you have 2 that are incorrect.
I would go with whats on the dipstick.
I now keep my naturally aspirated engines at 6 qrts instead of 8.
Much happier w 6 now.
337B
Philadelphia PA
Unread 09-06-20, 10:32 PM
Thanks for the tip Philly - I agree no need to always run full of oil. Maybe on a long cross-country, but that's about the only time I can think of I'd want full oil.
Unread 09-07-20, 03:33 PM
fsnewton's Avatar
fsnewton fsnewton is offline
Oil Level
Same here. I realized after the first two oil changes (and after removing lots of oil from the AC belly) that the dipsticks weren’t calibrated. We put in 8 quarts and it reads 6 quarts. Before that I thought my engines were “burning” oil but it seems it’s just been blown out the breather tube. I use the 6 quart mark now (knowing that I filled it with 8) until I can get the dipstick calibrated.
Unread 09-14-20, 08:53 PM
THIS^^^
I put in the remaining 1.5 qts, for a total of 8 qts added, plus a filter change. Filter was not pre-loaded with oil. Started the motor and ran it briefly, came back the next morning, and the dipstick reads 5.5 qts. So that's my new 8 quart baseline reading.
The dipsticks front vs. rear have the same initial P/N, but different letters at the end. I will continue to monitor and investigate.
If anyone has access to a TSIO-360 parts catalog, please post the proper dipstick P/N for the TSIO-360CB engines. Thanks.
Unread 09-15-20, 04:04 PM
Check out Continental SIL 00-7C you will have P/N 632062-20A1 or 632062-19A1 depending
on the last digits of your engine model ie TSIO360CB3. you might also check to see if the dip stick tube is coming out of the case.
Kim
Unread 09-15-20, 05:45 PM
Thanks Kim. The rear engine is a TSIO-360CB-6B. The dipstick currently installed is a 632062-19 BK. Photo attached.
Unread 09-15-20, 10:23 PM
That should be the correct dipstick
What I do is after an engine change at the first oil change I’ll put in 8 quarts and scribe a mark On the dip stick. It is always 1/4 inch below the 8 mark on the stick. The pilots run the engines at the scribed mark and the engines don’t seem to blow any out. Then at oil changes I’ll put in 9 quarts and after the run up the level will be at my scribe mark. 1 qt. goes in the filter. It’s the same on all 5 of our 337’s
