Unread 08-27-20, 12:30 PM
Frank Benvin's Avatar
Originally Posted by cartrm View Post
Thanks everyone for the replies. I have two gauges - one for the left side and one for the right, each maxing out at 59.5 gal/354 lbs.
Both fuel selectors only have L-Off-R. There is no Aux option. There is also only one fill point on each wing.
Yes yours only has one fill with three or four tanks interconnected can't remember. If you need full tanks. Fill one side full then go fill the other tank then come back to the first tank and top up then go to the other and top it up It takes a bit for fuel to flow between tanks
1967 337B
