Unread 08-27-20, 10:14 AM
Jhogan0101's Avatar
Frank, i was referring to cartrm. Was just using mine as an example
337B
Philadelphia PA
Unread 08-27-20, 12:13 PM
cartrm cartrm is offline
Thanks everyone for the replies. I have two gauges - one for the left side and one for the right, each maxing out at 59.5 gal/354 lbs.
Both fuel selectors only have L-Off-R. There is no Aux option. There is also only one fill point on each wing.
Unread 08-27-20, 12:30 PM
Frank Benvin's Avatar
Yes yours only has one fill with three or four tanks interconnected can't remember. If you need full tanks. Fill one side full then go fill the other tank then come back to the first tank and top up then go to the other and top it up It takes a bit for fuel to flow between tanks
1967 337B
Unread 08-27-20, 12:34 PM
Thanks Frank. So am I correct that there would be a sender in each tank, however many tanks there are, as well as a monitor on each side? I'm trying to understand the pennycap system to get a better idea on what it would take to put in the CiES senders and a new fuel gauge.
Do you have a parts catalog. All the info will be in their. I sold my 73P model in 1994 cant remember that far back
Unread 08-27-20, 12:41 PM
Why not install a FF totalizer and forget about the analog gauges? Analogs are only good for govt work - Only have to be correct when tanks are empty!
Unread 08-28-20, 09:31 AM
Yeah when I'm ready to redo the panel I'm going to be looking at a totalizer and primary engine monitor to replace the cluster. But after my annual, that will probably be a project for next year. In the meantime I'm trying to figure out of the inop gauge is truly shot or if there is a simple fix to get it going again.
Unread 08-27-20, 12:44 PM
1967 337B
Unread 08-27-20, 12:47 PM
Parts catalog is free to DL from Textron: https://ww2.txtav.com/TechnicalPubli...s/Book?PN=P607
You'll have to register for a free account before you can DL.
Unread 08-28-20, 09:33 AM
Thank for this. Quite surprised that anything from Textron/Cessna would be free...
