Unread 08-10-20, 12:19 AM
JeffAxel JeffAxel is offline
pictures, or it didn't happen! As to getting to the rear alternator, take the interior coverings off the rear wall of the cabin and there is an inspection plate you can remove to get access to the rear alternator and magnetos. What tail number did you buy?
Unread 08-10-20, 11:07 AM
Can't for the life of me understand how to post photos here. None of the photo options I'm used to seeing in other forums! And most of my pics exceed the 1MB limit.
Unread 08-10-20, 11:11 AM
Here is a pic of the CNX80 showing 210kts. I also attached the speed/altitude printout from the flight.
Unread 08-10-20, 07:21 PM
Nice, saw the advertisement. Do I remember that both engines were very high time? I was tempted to call our local engine shop (Premier Aircraft, Troutdale OR) to see what overhauls would cost for that plane but the ad was gone before i got a chance to call. Have fun with it, and I would suggest getting a Parts Manual and a Service Manual, very helpful items to have.
Unread 08-10-20, 07:50 PM
rrolland rrolland is offline
Congratulations! Enjoy flying the airplane. Looks pretty good.
Unread 08-10-20, 08:26 PM
Talking
Yep, that's the one. I was "johnny on the spot with cash" or I would've never been able to buy it. Seller had almost 100 phone calls within a few hours.
Greatest news is that engines times were being kept off Hobbs, but I found a log entry a few years back that says the engine times are much lower. The tach time is much less, closer to 1000. Either way the engines look like they're only a year or two old. Soft hoses, shiny clean surfaces, etc. I'm gonna replace a few cylinders on the back, but the front is all solid.
May do GAMI's, they are just up the road a bit from me. Not sure what the fuel flow mafia has to say about LOP operations on a turbo.
Unread 08-11-20, 12:01 AM
I had GAMIs on my P337 and the engines ran fine with them. Ran them at 65% power, 23-24gph total in cruise which got me a TAS of 185 in the high teens with cool temperatures even in the summer with the cowl flaps closed. My P337 had intercoolers, air conditioning and VGs so was slower than some, you might do better TAS wise. The best part was the cylinders looked clean as a whistle when we borescoped them. Never had to clean spark plugs.
Unread 08-11-20, 08:41 AM
Air conditioning is the ONE THING this plane doesn't have that I REALLY wanted. Intercoolers, winglets, STOL kits, and VG's are all cool (no pun intended), but when you walk outside into a North Texas August day - 100 degrees, 60% humidity - its AIR CONDITIONING your body and mind are wishing you had!
First flight, I took off south of Denver from about 6700' on a 90 degree day. Wouldn't want to do that in a non-turbo! Heat wasn't really an issue leaving Denver climbing to 17.5K, but cabin temps were beginning to get a bit uncomfortable during the last minutes of the flight as we descended down into the Texas heat to my home airport at about 700' elevation.
Whatever airspeed and useful load you may give up is WORTH IT to have AC!!!
Regarding GAMIs, do you lean to peak TIT, or wait for the last cylinder to peak as you lean for LOP operations? I got about 28 GPH, but I was feeding it fuel like a drunken sailor on shore leave. TIT never went above 1400. I actually ran the rear engine a bit richer to keep its temps in line with the front. Probably should've just opened the rear cowl, or just accepted the temp diff. CHT's were all well under 400, so it wasn't a huge deal, just 10-20 degrees higher in the rear.
