Unread 08-01-20, 12:00 PM
Red Air Rambo's Avatar
Hi Michel, a friend had one and he loved it...you will too! His ran a little hot on the rear and He added the cooling kit from Owen Bell which consists of about 3 more vents and an added scoop...but every plane is different so fly it first...if it made it this long without anybody adding it then its probably good. +1 one on everything Richard and Herb said. it's a plane that falls into the hot rod rule of "There's no replacement for displacement" lol.
Have fun,
Brent
Unread 08-01-20, 12:26 PM
mikezen mikezen is offline
mikezen is on a distinguished road
Smile
Thanks Brent !
Unread 08-04-20, 11:53 AM
JimC's Avatar
JimC JimC is offline
They're the same engines as the Cessna 340, so you can expect maintenance costs to be similar.
340s can cost upwards of $350,000 so owners aren't as surprised when they have a $25,000 annual.
337s often cost less than $100,000 so owners can be more surprised when an annual costs $25,000. (If a Rocket costs less than $100,000 it needs a lot of work!)
I've owned both a 340 and a 337. They each have their own uses. But don't expect one to cost less than the other.
Unread 08-04-20, 03:31 PM
Thank you Jim !
Unread 02-18-21, 06:40 PM
Correct me if I'm wrong, but IIRC, with full fuel, a Super Skyrocket has a payload of less than 200 lbs. There was supposedly an STC to increase grow weight to 5400 lbs, not sure if it ever happened: http://www.aero-news.net/index.cfm?d...4-6988ade12e5c
Unread 02-19-21, 08:12 AM
As an answer to Nate's (6498w) question :
"Hi Michel,
Did you end up buying the Super Skyrocket? I'm looking at one now and having the same thoughts you had when you started this post. I'm wondering if you have any insight you can offer after hopefully having a successful purchase!
Thank you,
Nate"
I finally did not buy the Riley Super Skyrocket I was looking at : it had lost it's Gross Weight increase to 5120 lbs.
With a 4700 lbs Gross Weight, it just isn't worth it : with 800 lbs useful load, you never can have full tanks (148 USG) : the aircraft becomes a Formula 1 !
