Unread 07-31-20, 11:29 AM
Yes, deice boots can be added to the Horton STOL wing cuff. The real question would be, is the aircraft already "PLUMBED" for boots? If it was plumbed from the factory, has all the vacuum pressure lines already installed but never had boots or the boots were removed, then it would be cost effective to add the boots. But if the aircraft is NOT plumbed, in my opinion it's not going to be cost effective to retrofit the application.
Remember, NONE of the Skymasters ever built were certified for icing conditions
