Unread 07-25-20, 11:36 AM
Bas
I am a BAS guy, installed in both of my aircraft. I like the 4 point system for safety, and they are comfortable to fly with. Can also undo the should harness in flight if you want. A little more work to install than Cessna (I believe), but not difficult to do over a weekend.
Unread 07-26-20, 10:38 AM
I have the BAS system and am very happy I took the time to install it when I did a refurb on the interior. I considered the Cessna kit but really glad I pursued the four point harness. I was concerned that they wouldn’t be comfortable in flight but I have never had to take them off for any flight. You could remove the uppers during flight but you won’t need too. Hooker Harness makes great belt system but I’m not doing aerobatics in my Skymaster. There is some talk about the concern of drilling through the forward spar for attachment but I think it is a proven system and am not concerned about the install. Go with the best system out there and for us it’s BAS. Protection is the best reason.
Unread 08-02-20, 11:16 AM
are there any shoulder belt systems for the rear occupants?
Unread 08-04-20, 11:48 AM
JimC's Avatar
JimC JimC is offline
The middle seats can get shoulder harnesses form serial number 1194 onward. The rear seats can get them from serial number 1317 onward.
My parts manual shows that the middle seats take the same shoulder belt assembly as the pilot & copilot. The rear seats take a different one. The part number varies with color.
I'm considering the 3-point airbag system from Amsafe instead of the 4-point BAS system (which is really a 3-point with a split shoulder harness.)
Unread 08-04-20, 10:37 PM
awesome. I'm in the serial number range. Looks like I take it just need to buy the parts/belts for the middle seats (the ones I want to do) and install. As you say, same belts as for pilot and copilot. Anchor hole for shoulder harness already installed at factory? (I'll be looking next time I go out)
Unread 08-05-20, 10:43 AM
JimC's Avatar
It looks like that to me, and others have reported finding mounting attach points under the headliner.
I can't upload the manual (too large) but send me a PM and I'll send you a PDF with the relevant pages & part numbers.
Unread 08-08-20, 10:55 AM
hayesjaj hayesjaj is offline
Can confirm the mounting holes on my 337G (1535). My interior is out right now and I can take pictures of the mounting holes tomorrow if you’d like. I plan to install BAS in the front, something with inertial reel in the middle and the straight cessna kit in the rear.
