Annual Costs
I think if you can get an annual done in 45 hours, you are getting a fair deal. While I do not know the Skymaster as well, 25 years doing annuals on my aircraft, I would guess that an average time to do a good annual on my single engine aircraft ran around 30 hours (doing it myself) - and that is after years of doing them and knowing the aircraft front to back. Given the complexity of the Skymaster (Retract tests, 2 engines, More panels and interior, etc) - I would think 60 to 80 hours is about right to do a solid inspection at a proper shop.
Don't confuse the price with the man-hours, as many people that have posted the < $2k annuals are doing some of the work in conjunction with an IA, thus saving a bunch of money with their own time. BTW - I am coming up to the end of an annual inspection on my Skymaster that had likely had the "minimal" annual inspections done for the past 10 years, and I am already 15 months into it (approximately 1000 man-hrs)...I do not want to tell you how much money I have spent. Of course I am doing lots of upgrades at the same time, but the maintenance neglect had certainly taken it's toll - most of which I could not pick up on the pre-buy inspection. Just one example - the shimmy dampener had a leak. Instead of removing it and resealing it, they kept adding fluid until the nose wheel would shimmy again, then top it up again. Sounds logical, right - that damn thing is tough to remove and reinstall. Bad logic...they obviously had some major shimmy at some points, and it caused over $4500 damage to parts in the nose gear and steering system, not to mention a lot of labor to remove the gear, do sheet metal work, and re-installation and rigging. I think of the annual as the investment to maintain the value and safety of my aircraft - not just an added expense. Jeff |
Very helpful responses ... as usual.
As it happens, this one has a collapsed nose gear (just the hydraulics). Can't wait for the fun to begin... |
Annual
So this past year, 2019, I had my annual done in NC at KEXX by Superior Aero Services. Thye are based on KEXX. For my Skymaster, a '76 P337G the flat rate was 4500. This included the entire process, as I was not available to help. So no savings in that. The list of squawks that came out of this was long. But a number of items that should not be repeated. O2 generators, major issue with heating unit, a broken switch for de-ice boots, and a few other odds and ends.
That quickly added up to another 6K. So with all items, I was into it for 10K. again as someone pointed out, a 10K investment on a bird that is 40 years old, totally worth it. If you can get you plane to Superior, they are good people and do good work. Frank |
I would also argue that an annual inspection should also include “annual maintenance” as defined by the Cessna maintenance manual (50hr and 100hr inspection checklist). Paying a flat rate for a list of discrepancies is only half of what needs to happen each year.
Hours for basic annual?
Hello ALL. I'm an A&P/owner of a '65 C337. I purchased this airplane 2 1/2 years ago. I spent the whole first year doing the annual. It had been maintained well prior to me purchasing it. There were three major problems, mostly gear issues which took most of that time. The fact is that I had only performed one other inspection on a C337 prior to doing my airplane. The second annual 2019 was done in about one week, doing all the work myself. Now there were things that I only had to visually inspect, the normal annual items, ie, brake work, spark plugs, checked engine timing, pulley/cable lube, removing and installing interior, battery service, I also install an ADS-B-out. I did have to pay an IA for the annual sign-off. All in all I spent about $1000, not including the cost of the ADS-B. Even if I wasn't an A&P I'd do my own work, I know of a lot of pilot/owners that do the majority of the work on their annuals and have the local IA sign it off. This arrangement is pretty common. The IA usually has the owner do the work with him the first time to make sure the owner can do the work properly.
BILLS |
FL and NC
Ric Burnette if near KFXE (Ft Lauderdale. FL)
Russell Hyde at Planewerks if near KFQD (Rutherfordton, NC) Both know Skymasters very well and are extremely fair on all work, including annuals... I've used both, and would not hesitate to use then again. |
My last annual was 42 hours but that was owner assist with me doing a lot of the time consuming removal of panels, seats, fairings, etc.
_________ John K 1977 337G CNC3 |
| Thread Tools | |
