Unread 11-28-19, 01:31 PM
Fuel Indications capacitance system
Hello all
Getting into repairing my wiring for the fuel indication system in my 74P model. Getting a test box on the way, what do you all think of this wiring black spot, and how would you fix it?
I am also not paying 250 for each gasket, which will be 4, I am making them out of Viton.
Dan
67S
File Type: jpeg 46D23511-E0A3-4A4B-8C97-8D156C8D7F1A.jpeg (653.7 KB, 2311 views)
Unread 12-01-19, 12:52 PM
Don't forget to file the Form 337 for the non standard gaskets
Unread 12-01-19, 03:06 PM
That would be owner produced
Unread 12-01-19, 09:10 PM
Nice alternative Dan, just so others understand this option
Owner produced parts in the reg's says
REPLACEMENT AND MODIFICATION PARTS(a) Except as provided in paragraph (b) of this section, no person may produce a modification or replacement part for sale for installation on a type-certificated product unless it is produced pursuant to a Parts Manufacturer Approval issued under this subpart.(b) This section does not apply to the following1) Parts produced under a type or production certificate.(2) Parts produced by an owner or operator for maintaining or altering his own product.(3) Parts produced under an FAA Technical Standard Order.(4) Standard parts (such as bolts and nuts) conforming to established industry or U.S. specifications.SECTION 21.303
More here https://www.savvyaviation.com/wp-con...uced-parts.pdf
