Old 11-14-19, 09:27 AM
GEM HP Palm Computer
I am looking to find a working, or repairable HP Palmtop with the Insight GEM software on it. I wanted to track some trends on my rear engine. I plan to replace the engine monitor in the spring, but for now, need to download info. Anyone have any leads or ideas?
I called insight, they say they no longer have or support, so the manufacturer is no help. I have found an HPLX but no joy on the GEMCOM software, if anyone has, well that would be great. It is likely a PC-CARD that installs into the HPLX - I can copy if some has one they can share.
Please let me know.
Old 11-16-19, 09:40 AM
I poked around and find it odd that there is not a copy of gemcom.exe out there.
What analyzer are you going to replace the GEM with?
Old 11-16-19, 11:27 AM
kbecker kbecker is offline
Frank,
I have the GEM software! It’s present on a memory card that plugs in to the HP 95 or HP 200. Do you have the adapter that allows you to use the memory card with your HP?
Old 11-16-19, 11:28 AM
I also have a functioning HP 95 and HP200.
Old 11-16-19, 11:40 AM
See photo of the HP screen. I think this is what you need
File Type: jpeg 64D7CAEA-90C7-41B7-A859-AEBE0AFA9342.jpeg (329.0 KB, 2057 views)
Old 11-16-19, 01:05 PM
Hp and Gem
So I would love a copy of the software. You can email me with info. Frank.oconnor19@gmail.com
I was thinking about going one of three ways. A G4. Basically nothing more then what I have, but up to date on displays and software. A jpi960. Replace all of the legacy engine monitoring systems or a garmin EIS as I have all glass for flight systems
Each has a progressively larger price tag. Lol
Old 11-16-19, 03:11 PM
Do you need the functioning HP or do you have one?
Old 11-18-19, 06:52 AM
Hplx
I had purchased one from eBay last week. It is due this week. So the short answer is maybe....I will let you know. Thanks
Old 11-18-19, 05:05 PM
I emailed the software. Did you receive it?
Old 11-19-19, 11:30 AM
Software
I did not see an email from you. Please confirm the email address.
Old 11-19-19, 11:32 AM
I will resend this evening
Old 11-21-19, 12:54 AM
I resent. Did you receive the email?
Old 11-21-19, 10:51 AM
Gemcom.exe
I did not get it. If you are sending as gemcom.exe lots of email systems will stop that. If you have a chance call me. 917-648-3839
Old 11-22-19, 06:27 AM
Success!
Thanks to a little field engineering, and some luck I now have a working HPLX 200 palm computer, with a working copy of GEMCOM on a compact flash card. I was able to get it formatted so it can be read in both my windows 10 computer and the HPLX for the interface to the GEM1200. Clearly this is not a modern solution, but the data is there and with a little experimenting I found the spot where I can hold the computer to get the interface to work. There is a reason that IRa interfaces did not catch on, they are very temperamental.
In any case I was able to unload data and graph it on my computer. showed some interesting results, confirmed what I suspect is a bad wire or fouled plug in Cyl1 rear engine, I am posting screen shots of CHT, EGT for both front and rear from my last flight, would love some feedback from the group. Thanks in advance.
You will notice a decline in temps and then a rise and decline towards the end of the flight. I executed a go-around as it was a new field, short runway so I did a fly over to check it out.
Old 11-22-19, 03:24 PM
Nice work recovering the data! Yeah, probably something related to a wire or plug.
Below is from Things That Effect CHT"
"Failure of one spark plug or magneto can also affect CHT, because the air-fuel mixture takes longer to burn when it is ignited by only one spark plug instead of two. This causes θpp to occur later and CHT to decrease".
