| Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
Bob, have you got a leaf blower to connect to the scat tubes and confirm that the valves are opening?
_________ John K 1977 337G CNC3 |
I do great idea will try it today thanks
Thanks for the tip John. I did get some airflow out of the defrost, enough to make a tissue move and much better airflow out of the vents below the left and right seats. I guess my recirculating fan needs to be replaced $$$$
Ask your A&P if he'll let a motor shop that works on DC motors take a look at it. It's becoming more common as the legacy fleet ages and parts cease to become available. If they can find an issue with a bearing/winding/shaft etc maybe he'll sign it off.
John, I just had the motor fixed so I believe the squirrel cage is allowing bypass since I get good airflow from it but no pressure
1969 version
My older T337D relies on ram air pressure, so you only get good defrost in flight.
On ground, not much at all, just from front prop backwash into ducting. The only motor is the one mounted on the heater for combustion air flow. You 'throttle back' that back (partially close duct) in flight because adding ram air is too much.
David Wartofsky Potomac Airfield 10300 Glen Way Fort Washington, MD 20744 |
| Thread Tools | |
| Display Modes | Rate This Thread |
