Unread 07-03-19, 12:44 PM
There are several connector in the system which I would check first. I have the most trouble with the connectors on the wing root. take off the most forward round panel at the wing root and check the connections there. my airplanes have 2 plugs for each wing and the wires are black and yellow. the other connections are at the computer in the overhead and under the round panel on top of the wing where the probes connect. i would surely check that before I would replace the cables.
Kim
