Unread 06-20-19, 09:08 AM
Originally Posted by dan1000 View Post
As strange as this might sound, try inserting the dipstick until it becomes difficult, then grab it about an inch above the tube and push from there (rather than simply pushing it from the handle). You may find that it is easier to insert when done this way. Use a rag or paper towel to hold it if you like.
Dan
The dip stick was twisted and in really bad shape ,we did change with new one and also mechanic did some work with the dip stick passage and now working fine. but still it requires a certain technique to insert it inside ;-)
