Unread 01-27-19, 08:56 PM
DrDave DrDave is offline
Hi BILLS:
The circuit wires on my panel are mostly original. The eight-place circuit bus is for the avionics. I'm doing the Approach Fast-Stack system. All of the avionics power wires will go to that bus and the grounds will go to a dedicated single-point ground bus for the avionics. I ran parallel #8's to feed the battery, these are replacement/upgrades. The original charge wire had a poorly crimped end that was burnt from a poor connection. The alternator feed wires are new all of the way to the alternators.
What is the serial number of your plane? I will look and see if I have the wiring schematic for the alternator system.
Hope it warms up there soon. We can certainly make a list of things to check so you don't spend too much time in a freezing hanger.
