Jeff, I can't see any benefit to eliminating it? I don't have any issues seeing out the front.
_________ John K 1977 337G CNC3 |
Thanks John for the quick response! Also, keep up the photos and videos on the Facebook page; they are great!!
Jeff |
For perspective, I was a helicopter owner/pilot first. So transitioning to fixed wing for me was like learning to drive a submarine. All that stuff in the way out front. Cant see anything.
One of the reasons I liked the 'thrasher was at least the sides were wide open. Your head is ahead of the wing, so side view is basically unobstructed. That said, I think the one piece out front makes a HUGE difference. When mine was done a thousand years ago, it was time to replace the windshield because it had become so hazy. One particular landing into the setting sun had been like Lindbergh landing in Paris. I had to look out the sides to decide when to flare. That was it. Being a relentless nerd, I did some research. The original 337 windscreen is/was very thin, light, (weak) Plexiglas. I don't recall the thickness, but it was very thin. It was and remains today a single piece, with a center bracket for support. (That is of course after first weakening the windshield by drilling holes in it for the center support bracket!). So the old super thin Plexiglas definitely needs support. When I was exploring this, there were still some old timers at Cessna very familiar with the airframe and testing. Cessna told me the original windscreen was thin Plexiglas, for weight and optics, because that's what they did back then. Any thicker would get heavy and wavy. They also noted that the most sound reduction in any aircraft came from going thicker on the front window. Apparently lots of experience with single piece conversions on C210, 182 etc. Reduces the beat of props, wind, etc. So I went with the thickest windshield I could get installed, and have never looked back. And yes, it is a LOT quieter, and I MUCH prefer the unobstructed view. From a helicopter pilot's perspective there is STILL that front engine, prop, and all those gauges in the way, but I've got used to it. My T337D is NOT pressurized, which might be another factor to consider. Commercial jet windows blow OUT. If you see how the window is installed, if done correctly it is NOT coming out. Nor if using modern thicker plastic is it ever going to break. One of our based pilots, Alfonso, also on this board, researched this extensively before doing same with his 336. He was a former FAA inspector and could find zero incidence of any windshield issues or failures. That said, he did the STC and managed to hit a bird, or went into a thunderstorm and THEN hit a bird, so the window broke! So don't do that. Another strategic trick is I have the airplane tied down outside facing NORTH. Why? Well, the wings are facing SOUTH, so de-ice faster in the winter, AND the sun's angle of incidence on the modern Plexiglas is slight. High end auto restoration friends had also told me to never use a cover, because they tended to accumulate grit underneath that ground the surfaces beneath in the wind. After more than 20 years since the windshield was replaced, tied outside continuously in Washington summers and winters, with no cover, it is almost as clear as new. The STC may actually be just one of those STCs designed to require you to pay them money for a piece that effects nothing. I would look into the actual history of issues, if any, then decide. So far so good.
David Wartofsky Potomac Airfield 10300 Glen Way Fort Washington, MD 20744 |
http://www.lpaero.com/images/cessna1.html
The Original Cessna Design: The center strap provides positive retention of the windshield at the top of the cabin. Positive retention in channel is necessary because this area operates in a negative pressure environment and could "pop out" if not positively retained. Windshield thickness increases are implemented where the original windshield was 1/8" or 3/16" thick. So there!
Thicker window
Hi David,
Thanks for your feedback and data. I am curious to know the mod you have for the thicker window? I can only find data that reflects Cessna 337 windshield is 0.250 thick, and that is the only thickness I have found for replacement. The STC I am looking at does provide retention at the top and bottom of the window in the center portion, but does not include the windshield, just the sheet metal plates for reinforcement. Any guidance on where the thicker windshield could be acquired? Thanks, Jeff |
It's been a million years since mine was done, but here is one source.
http://www.glapinc.com/Cessna/337/337a.htm Here is a refence for what they originally used on C170s. As I recall, the original on my '69 'thrasher was also super thin. "The original windshield was 1/8" thick thereby needing the aluminum center strip(IPC 051000-16) down the center (giving rise to the erroneous "two-piece" name). Any thickness windshield you buy can be tinted. If you select the 1/8"thickness you must use the support strip. If you order the 3/16" thickness you may opt to leave off the strip*. You may not be able to install the new windshield an easily without drilling off …" http://www.cessna170.org/forums/viewtopic.php?t=554 And another interesting article: https://www.avweb.com/news/features/...-225181-1.html
When replaced, my original windscreen was the original, 1968 installed at Cessna. When I replaced mine I purchased from Great Lakes Aero Products and it was the same thickness as original. That was the only option, no option for thickness as I have never seen an STC for thicker windscreen. Saying that I would not be surprised if the 336 had a thinner windscreen and when Cessna designed the 337 they settled on what we have today. Mine is a "C" model so I could be referring to only up to a certain serial number. On GLAP website it lumps serial number 2 - 1426 as all the same replacements. I kept my center strap because I was told it was there to hold the top of the windscreen because if enough stress is on the fuselage it could pop out. After struggling for hours, days trimming and fitting the new windscreen I found that there is really not a whole lot holding that windscreen in place at the top. Of course today's Pro-Seal is probably stronger than the old sealant that Cessna used I still kept the center strap. Besides I like my compass suspended. I have seen several center strap deletions and they do look nice.
Please do not use Silicon Sealant on your windows. Pro-Seal is the only way to go
| Thread Tools | |
