Old 08-07-18, 12:53 PM
BillS
There is and never was an AFM for early models. Find a different CFI, good grief these people are insane !
Old 08-07-18, 05:15 PM
cessnadriver's Avatar
Red face FAA Airplane Flifght Manual (AFM)
Ya, I know. But here's the thing. I need to use this MEI because the other MEI I was going to use has a Air charter business and is much too busy. The new MEI is located right here at my local airport where my plane is. This is TOO good to be true! I understand that the issue to you and me are pretty trivial but this MEI is concern with the FAA flight Examiner and his view of this AFM issue. I have printed out the commits from Cessna publications and AC 60-6 para 5 as proof that my older C337 does have an AFM. I appreciate your commits.
Regards.
BILLS
Old 08-08-18, 07:58 AM
Flyer770 Flyer770 is offline
Flyer770 is on a distinguished road
Everything I’ve seen with the older stuff is the owners manual, along with an airplane specific weight and balance form and equipment list attached and the cover marked with the registry and serial numbers. Seems to satisfy the local CFIs and DFEs. Maybe it’ll be good enough for your preferred CFI?
Old 08-08-18, 08:15 AM
Question FAA Airplane Flifght Manual (AFM)
You mentioned that a serial number and registry on the cover? I have only seen this on newer aircraft, according to Cessna publication department AFTER 1976?
Thanks for you input.
Regards, BILLS
Old 08-08-18, 08:37 AM
Yes, once the empty weight and balance sheet is made out for your exact airplane, staple it in the back of your owners manual and write the N number and serial number on the front cover. Or write in your exact empty weight inside. Or both.
Old 08-08-18, 04:54 PM
Smile FAA Airplane Flifght Manual (AFM)
Thanks for the information. I talked with my local FSDO and the flight examiner. The flight examiner agreed with the FSDO that Cessna DID NOT issue a flight manual for my 1965 and his suggestion was to print and attach the e-mail from Cessna pubs. to my OWNER MANUAL. I could also write my serial/"N" number to the cover.
Thanks again.
BILLS
Old 08-10-18, 09:34 PM
general's Avatar
general general is offline
I swear some of these examiners now days, you have to wonder how they got to be examiners. No AFM for early models, the military did develop a AFM of sorts for the 02 s but not for civilian, I agree Find a different CFI
General Sky
