Unread 04-09-18, 03:37 PM
dan1000 dan1000 is offline
Thanks, General. I will give it a try by the POH original numbers, and see how that goes. I had assumed it would float forever at original numbers, but we'll see
Dan
Unread 04-09-18, 04:10 PM
general's Avatar
general general is offline
No you're not going to see much float at all , as soon as you get on the ground and dump the flaps it won't fly. As long as you're not giving it power. You'll have much more control coming in on Final however it will feel like you have more Authority with the STOL kit. You can do some touch-and-goes it will want to take off early and you got to keep the stick forward, but if you rotated standard speed your rate of climb will feel much greater initially.
Have fun.and be safe.
General Sky
