Old 04-26-17, 12:02 PM
LostKiwi's Avatar
LostKiwi LostKiwi is offline
Whats the cost of overhauling a mag vs installing an electronic ignition?
Leighton.
Old 04-26-17, 01:17 PM
$750 to $1000 in most cases. Electroaire are in the $3000 range
Old 04-20-21, 09:38 PM
Surefly
Surefly is another certified option to replace 1 magneto. Need a slick harness and engine analyzer. $1695 per.
Old 04-21-21, 12:08 PM
Surefly seems like they intend to put Electroaire out of business.
$1695 vs. $4400? I just checked, those are the current prices for a Cont. 360 setup.
And the install is much simpler with the SureFly, it just replaces the existing mag (after adding a power circuit), whereas the ElectroAire requires the additional installation of a magnetic crank position sensor.
Old 04-22-21, 07:53 PM
cessnadriver's Avatar
Mags
FOR: JB78382.
Hello. I'm pretty sure the 500 Hour is an INSPECTION not an OVERHAUL, especially under the Part 91. Your local A&P mechanic can do the inspection without much trouble. Although the mags are difficult to remove/install, time consuming maybe 6-8 hours total. Especially if the A&P hasn't have much Skymaster maintenance time. Hope this helps.
Regards.
BILLS
'65 C337 Owner, pilot and A&P
Old 05-04-21, 01:48 PM
chrisb chrisb is offline
chrisb is on a distinguished road
Mags
Hey All,
I've just had the mags of the front engine inspected in line with the 500h engine and air frame maintenance schedule. It's worth doing imho. There have also been a fair number of SB's on these mags across their lifetime.
Pain in the ass to get off though :-D
P337H Sn: 0318.
Under restoration
