Bob,
The retainer and bearing assembly (complete) is 1560141-1 for the left and a -2 for the right. The individual bearings are S-2010-3. Looks like the Usable On Codes are the same for the entire P-model serial number range.
Somebody mentioned using heat shrink tubing... think that was a CPA fix. Seems that would work if the thickness was right, and then trim away the excess near the center.
Keep me posted how you manage this one as mine need fixing too.
BTW, want to try 20-meters? Haven't checked the bands but if you're up for it, let's try 14,337.0 Khz. (WA7BZI) You can drop me an e-mail if it's a go.
SkyKing
