Old 07-08-15, 02:28 PM
rmorris rmorris is offline
exhaust-ing
About 4 weeks back I had a very, veery small crack in the exhaust of my t337c. Taking the pipe off to see if we could get it repaired locally, the beaded ring under clamp showed great wear and a piece broke off....so took off the entire system for inspection. Overall everything looked pretty good, but Acorn in CA convinced me to send it all in for better inspection and to ensure a good fit for the repaired piece at least. They said, and I quote "send it via 2-day air to us, and you'll be back flying by next weekend"....that was a month ago. in the meantime they naturally found my entire exhaust not acceptable and after 6K finally returned my 'repaired' exhaust to me yesterday (did I mention it has been over a month now?)...went to put it on last night, and the fit is horrible. See pics. this morning I sent them link to pics and asked wth? it took 3 hours to get a phone call back. So far not an Acorn fan.
question I have for others with T-models...see the pic where the collector and elbow coming up from turbo are so far off? I am concerned not just with the huge gap, which they say they will look at and fix, but at the extreme angle in which they meet up. Roy at acorn tells me that huge angle is normal for our planes, and that they never meet up at a perfect angle...really? That huge of an angle for the tow pieces to meet. anyone got pics of their exahust in that area they can share?
Old 07-08-15, 03:38 PM
Robert
It doesn't look right to me. I can't see how that is going to mate up. I have not dealt with Acorn but have seen their ads in places. Too bad you could not have them disassemble and then put it back on. These guys always pass the buck. Your luck in maintenance shops has been less than normal. Sorry to hear........
Old 07-09-15, 10:02 AM
exhaust pics
Anyone with a turbo model got any pics of their rear exhaust, specifically the left hand side (pilot side)?
Old 07-09-15, 10:40 AM
JamesC JamesC is offline
Just eyeballing the set up – does it fit better if you rotate the collector 180° about the vertical axis and reinstall it? If the exhaust is fresh you should be able to easily rotate all the slip fittings to adjust/adapt angles slightly…
Old 07-09-15, 10:56 AM
tried all kinds of yoga
good thought, we had it too...we tried all kinds of different combinations, thinking maybe they had just shipped the header pipes to us in the wrong spots...so we tried different combinations of those, and of course the collector in both ways.
We had anti-sieve applied, so was time consuming but pretty straight forward to pull back down and re-try different combinations.
The entire stack, no with my controller bracket, were shipped back P1 last night....they are suppose to throw back on their jig today and try to figure out. I was hoping for some pics form other T-model installs to give them more reference, especially around the collector meeting that elbow....I am concerned that they will just rais it enough to meet, but it will still be at that steep angle which seems odd to me...but i could be wrong.
Old 07-09-15, 11:46 AM
My T-model is in another city but will try to get some images.
Old 07-09-15, 01:15 PM
Mine is a 1979 so is different but still there are no angles into the turbo inlet only curves.
Unrelated you will notice a crimped off line in the top left - goes off the upper deck to the pressurized mag - received the inline filter so line is about to be re-connected.
Old 07-09-15, 03:28 PM
from the parts manual
Name:	Screenshot 2015-07-09 15.26.41.png
