Old 06-22-11, 12:57 PM
Fuel Hose Source
Any recommendations on suppliers for fuel hoses for the rear and front engines? I have a couple of chafed fuel lines that I feel should be replaced. Wondering where to buy, cost vs. quality, with or without integral fire sleeve, etc.
Old 11-02-13, 05:30 PM
sdellinger sdellinger is offline
sdellinger is on a distinguished road
When to replace engine compartment hoses?
Where can I find info on when all flexible hoses in the engine compartments MUST be replaced. All I can find are recommendations on when to replace those hoses, but I can't find anything directive.
Thanks!
Old 11-03-13, 07:03 PM
There are some AD's for aircraft but I am not aware of any for the Skymaster. Typically the service manual suggests when engine is overhauled the hoses should be changed. Check the service manual.
Hoses are available with or without fire sleeve. Your mechanic should have sources and can buy the fire sleeve bulk to install on the hoses purchased.
Old 11-22-13, 12:26 PM
rmorris rmorris is offline
hoses
I use Precision Hose Technologies (PHT), and have been very happy with them. I have also been happy with my Aviall hoses - both good sources.
For PHT, I just send them (with the a&p's help) hose length, and connection fitting sizes on both ends - they fan firesleeve, or not, as you desire. I firesleeve most of mine.
I have used PHT for all engine hoses, and in both compartments, as well as hydrualic system hoses.
Good luck,
Robert
Old 11-24-13, 11:12 PM
GEE-BEE GEE-BEE is offline
GEE-BEE is on a distinguished road
Wink Teflon hoses
I can do your teflon hoses in various colors
all with tso and certs
Colors:
Marron
Brown
Med Blue
all with s/s fittings
I will be doing a black firesleeve next ( slip ) on type with teflon hoses underneth for a stc holder that requires black hoses with hose black baffles and seals
P.S. I also ave all the original patterns for the 336-337-P337 and Riley Rocket 337 baffle seals.
baffle seal colors :
Champion red ( Riley)
Med Blue
Black
Dark Blue
Scat orange
regards Guy Ginbey
Gee-Bee
n77gb@msn.com
ID:	1506   Click image for larger version
Name:	late gear v35 002.jpg
ID:	1507   Click image for larger version
Name:	Engine in the Bonanza 7-26-2012 001.jpg
