Unread 08-27-13, 11:15 PM
Frank Benvin's Avatar
Go for it my dad at 55 did half of his training on a single and the balance on a C337b He did his ride for his private licence in the C337b Now he is 83 and still flying his C337b
Frank
Unread 08-28-13, 03:03 PM
bjherron bjherron is offline
bjherron is on a distinguished road
I bought my P337 before I finished my private certificate, and started flying it with about 75 hours. In the following two years I put about 150-200 hours of flying time on it.
You just have to be careful that you don't get into situations (i.e. weather) that exceeds your experience. Also, plan on a LOT of dual time before you start soloing in the 337. I had about 25 hours of dual before I started taking solo cross country trips.
Unread 08-29-13, 03:13 PM
My initial reaction was to disagree about the number of dual hours. You see, after you've flown a 337 for a while, it's so easy, the aircraft so forgiving, that I thought 5 or 10 hours of dual, after your single private, would suffice. So I started writing a response along these lines, then decided to go find my 15-year-old logbook where the 337 dual was recorded and, surprise, I had about 30 hours. Oh, that's after my single private and a thousand hours of simulator time, most of it on multi-engine.
Anyhow, long response to say, yes, you'll need a LOT of dual time to fly a 337 safely.
Unread 08-29-13, 10:29 PM
There was a C model for sale over in Paonia at the airport. I heard that it was a pretty nice Skymaster for a reasonable price. Not sure if that is in your area or not.
Once you get the bug you won't be satisfied till you taste the real thing .........
Unread 09-12-13, 12:55 PM
JamesC JamesC is offline
Congratulations on not going the SR22 route. Obviously will in part depend on your skill level - I was not ready right after PPL. Bought my first Skymaster at 300 hours. Just don't get seduced by a marginal mission just because you have 2 engines (eg. as you know plenty of dead Cirrus pilots likely over-relied on the fact that they have a chute in their decision making process). Also be very careful about which 337 you buy - plenty of problem aircraft out there for sale with the oil all cleaned off.
Unread 09-20-13, 06:38 PM
sns3guppy sns3guppy is offline
sns3guppy is on a distinguished road
You will love handling and high density altitude performance. Leadville, Granby, Telluride and Glenwood Springs will be easy for you even on a hot July afternoon.
Flying to those locations is easy when all is working well.
You won't like them if you experience an engine-out, and that should always be your first consideration when flight planning. We don't plan for everything to work; we plan for failures, and then know we're safe when we can still work the emergencies and have enough margin of performance to get by.
Sometimes people mistake good two-engine performance for a pass to go places they ought not, conveniently forgetting what happens when power is lost. Same for the single engine crowd that forgets basic airmanship is always keeping a landing site within gliding distance.
Unread 09-23-13, 03:22 PM
Apelsin Elise Apelsin Elise is offline
Apelsin Elise is on a distinguished road
Of course. You are absolutely right.
Training and planning should never be discounted, especially when flying over extremely hostile terrain: Fly early in the morning. Always check density altitude. Check winds. Fly light. Always (try to) have an out. Take mountain flying course. Read books on mountain flying. Stay proficient. Don't get into the weather. Be prepared.
However, everything happens in a context. Short of turbines, what other twin would you prefer to be in while having an engine failure on takeoff from a high DA mountain airport?
Engine failure after takeoff from Glenwood Springs spells trouble for any piston twin. Most likely it will end in a crash. And crash options are not pretty in Glenwood Springs. My point is that turbo Skymaster or P-Skymaster will do better than most of the other piston twins there.
OP asked about Skymaster performance in the context of flying in Colorado. While I have never experienced complete engine failure in my Skymaster (yet), I have had partial power loss and other system failures over the mountains. It was not fun, but my P337 made it manageable. And, so far, safe.
Would you suggest another twin better suited for the OP mission? If yes, which one and why?
Speaking about single engine piston airplanes always keeping a landing site within gliding distance... this is (realistically) not an option in Colorado. You either take your chances while keeping your time over "no landing options" terrain to a minimum... or you stay home.
Alex
