Unread 03-07-12, 09:43 AM
Form 337
I already sent this to Tracy, but I thought I would post here in case anybody else wants the info. Attached is the form 337 for my aircraft for the installation of paralleled voltage regualtors. It's a very simple operation. The original VR's were replaced with the same regulators used in 400 series Cessnas.
The original Form 337 I got from CPA also showed the replacement of the orginal alternators with 60 Amp alternators. I didn't do that, so my From 337 doesn't show that information. Unfortunately, I can't find the orginal form. But as I remember, all that was necessary was to swap out the alternators and run a larger gage wire from the alternator to the buss.
Over the years, this installation has been trouble free for me. Both alternators are always "on line", and my volt/ammeter shows they share the load fairly well.
Mark
Mark Hislop
N37E
Unread 06-22-12, 02:44 PM
wybenga wybenga is offline
wybenga is an unknown quantity at this point
60 Amp Alternator 337
I have a 337 for N1049D as well as a supporting letter from TCM if you still need this information
Jack
